Basic M40 Servicing
Revision as of 23:28, 5 March 2009 by 203.184.28.37 (talk)
M40 Engine - Basic Servicing
Scared of the Spanner?!
This guide was made for you!
  • Coolant Change
  • Oil Change
  • Spark Plug Change
  • Masking tape + pen
  • 19mm Spark plug tool
Overview of an m40
Do the coolant first…
        • Disconnect Battery****
Oil change is easy...
Spark plugs...
This article is copy write to E30zone and must not be replicated without prior permission. Written and photographed by Neil Purdom == Alternativly remove the piece of shit M40 and put a M50 in it (it is 10 better) ==
Headline text
Headline text
