Z3 short shifter conversion
Revision as of 04:31, 24 November 2010 by Ugirylylov (talk | contribs)
This Page Is Currently Under Construction And Will Be Available Shortly, Please Visit Reserve Copy Page
CLICK HERE
Parts Required.
Description Part Number Price (£) Quantity Total Price (£)
Recondition Parts Gear selector rod joint 25 11 7 501 309 14.39 1 14.39
Dowel pin 23 41 1 466 134 0.29 1 0.29
O ring 25 11 1 221 243 0.31 2 0.62
Spacer ring 25 11 1 220 199 0.12 1 0.12
Circlip 07 11 9 932 863 0.12 1 0.12
Short Shift Parts Gear lever 25 11 7 527 252 36.46 1 36.46
Spacer ring 24 11 1 220 439 0.30 2 0.60
Circlip 25 11 7 571 899 0.37 2 0.74
Shift lever bearing 25 11 1 220 600 6.08 1 6.08
New gasket Exhaust gasket 18 30 1 711 969 7.96 1 7.96
Total 67.38
