Motronic
The Bosch digital Motronic ECU replaced the older analogue L-Jetronic system.
Contents Motronic ML1.X Motronic 1.1 & 1.3 See also References External links
Motronic ML1.X
Motronic 1.1 & 1.3
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. Alternatively, the existing EPROM can be blanked in an ultra-violet EPROM eraser and a new program burned into it using an EPROM programmer linked to a PC.
Hexadecimal Language: 85 0A F0 30 F0 51 D5 08 4E E5 09 B4 00 24 43 C1 C0 C2 AF C2 93 F5 C6 D2 AF 53 C1 3F 74 F4 25 C6 F5 C6 74 01 35 C7 F5 C7 43 C1 80 D2 93 75 08 0A 80 67 B4 01 24 43 C1 30 C2 AF C2 92 F5 C4 D2 AF 53 C1 CF 74 F4 25 C4 F5 C4
The EPROM in a 320i or 325i is a 27C256 type, a 28-pin DIL (Dual In-line) chip. It contains 256K of CMOS memory (arranged as 32K x 8-bits).
References
^ [2]http://www.ludd.luth.se/~rotax/motronic/motronic.html
^ [3]http://frwilk.com/944dme/
^ a b c [4]http://www.opel-scanner.com/files/Opel_MotronicML4.1.pdf
^ a b c [5]http://www.taylor-eng.com/ecu/motronic_intro.html
^ [8]http://www.opel-scanner.com/files/DME_1.1_1.3.pdf
