Motronic
Revision as of 18:36, 30 December 2008 by 91.111.127.108 (talk)
Bosch Motronic ECU
Motronic 4.1 The Motronic 4.1 system was used on Opel/Vauxhall 8-valve engines from 1987-1990[4], and some PSA Peugeot Citroën XU9J-series engines[5].
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. Alternatively, the existing EPROM can be blanked in an ultra-violet EPROM eraser and a new program burned into it using an EPROM programmer linked to a PC.
Hexadecimal Language: 85 0A F0 30 F0 51 D5 08 4E E5 09 B4 00 24 43 C1 C0 C2 AF C2 93 F5 C6 D2 AF 53 C1 3F 74 F4 25 C6 F5 C6 74 01 35 C7 F5 C7 43 C1 80 D2 93 75 08 0A 80 67 B4 01 24 43 C1 30 C2 AF C2 92 F5 C4 D2 AF 53 C1 CF 74 F4 25 C4 F5 C4 74 01 35 C5 F5 C5 43 C1 20 D2 92 75 08 0A 80 40 B4 02 14 10 F1 06 D2 F1 7F E6 80 02 7F 1B C0 F0 12 70 75 D0 F0 80 26 B4 03 1A B2 F1 90 01 62 E0 A2 F1 92 E3 F0 75 83 A0 75 82 21 F0 75 82 05 74 00 F0 80 09 B4 04 04 B2 EA 80 02 B2 10 75 08 64 85 F0 0A 22 90 47 9F 74 22 93 C3 95 3B 50 03 02 81 70 78 81 79 2E 7D 06 12 06 86 C2 D5 74 23 93 B4 FF 03 02 80 C2 12 81 9A 74 28 93 B4 FF 03 02 81 67 F5 F0 30 78 0A 30 03 04 C2 78 D2 79 02 81 67 E5 3B 70 03 75 68 32 D5 33 03 02 81 24 E5 F0 C3 13 F5 F0 B5 33 13
See also Jetronic
