Motronic
It was originally developed and first used in the BMW 7-Series[1], before being implemented on several Volvo[2] and Porsche[3] engines throughout the 1980s. It was also used on turbocharged Audi Quattro models during the early 1990s.
Motronic 4.1
The Motronic 4.1 system was used on Opel/Vauxhall 8-valve engines from 1987-1990[4], and some PSA Peugeot Citroën XU9J-series engines[5].
Motronic 1.1 & 1.3
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. Alternatively, the existing EPROM can be blanked in an ultra-violet EPROM eraser and a new program burned into it using an EPROM programmer linked to a PC.
See also Jetronic
