Basic M20 Servicing
UNDER COSTRUCTION, PLEASE SEE THIS POST IN RESERVE COPY
M20 Engine - Basic Servicing
Scared of the Spanner?!
This guide was made for you!
Respect it (bolts are more likely to shear if you hit the spanner with a sledge hammer!) <br>Stay calm and take your time. <br>Don’t get distracted. Keep Children, pets and nagging wives/husbands well away.
Tools and Parts Required
8mm socket (for bleed nipple)
!Oil Change
!Spark Plug Change
Masking tape + pen
19mm Spark plug tool
Overview of an M20
<br>
<br>
Coolant Change
RHS=Right Hand Side<br> LHS=Left Hand Side (sitting in driver’s seat)
Tip: spray the bleed nipple with WD40 the night before you do this
****Disconnect Battery****
1.Loosen off and remove the cap on the header tank (On RHS next to wing). Check the surface of the coolant for an oily film. If there is one the head gasket could be on the way out.
Move the heater temp control to fully cold to prevent air locks in the heater matrix
5.Insert hose into header tank (next to RHS wing) and flush system until water is running clear.
8.Pour the coolant into the header tank (located on RHS next to wing) SLOWLY and give it time to settle. (should take about 4.5l to get to cold level marker)
11.Open the 8mm bleed nipple (on top of the thermostat housing) and allow air to escape, then close.
12.Repeat bleeding until all air is out and only water comes out when bleed nipple is opened. Top up if required.
Oil Change
3.Remove oil filler cap and let car drain for 10mins.(can check how much is left using the dipstick) Check the cap for ‘mayo’ which could be a sign that oil is mixing with the coolant (not good). It can also be caused by the car doing low milage or not getting up to temperature properly so don't instantly assume the worst!
Spark plugs
1.Remove the Spark plug leads ONE AT A TIME and (using masking tape + pen) number them 1-6.
!This article is copyright to E30zone and must not be replicated without prior permission. Written and photographed by Neil Purdom
