MediaWiki API result
This is the HTML representation of the JSON format. HTML is good for debugging, but is unsuitable for application use.
Specify the format parameter to change the output format. To see the non-HTML representation of the JSON format, set format=json.
See the complete documentation, or the API help for more information.
"warnings": {
"main": {
"*": "Subscribe to the mediawiki-api-announce mailing list at <https://lists.wikimedia.org/mailman/listinfo/mediawiki-api-announce> for notice of API deprecations and breaking changes."
"expandtemplates": {
"*": "Because no values have been specified for the \"prop\" parameter, a legacy format has been used for the output. This format is deprecated, and in the future, a default value will be set for the \"prop\" parameter, causing the new format to always be used."
"*": "[[:E30 Zone Wiki:Sandbox]]"
